Edge Fade and SS4/5
Hey all.
Ive had this problem for a long time, since release I think, the edge fade inner effect and Mike Schleys Forlorn Cottage, Dungeon and city templates.
I always get this effect when I use it.
And at times when i zoom in and out the effect in the program goes bananas and leaves spots and dots all over the place.
When im the program the edge fade seems to be connected and triggers when you zoom. The more you zoom the more it fades the layer.
I've tried a solution I heard about on Facebook where you added a pinkish layer under the edge fade layer. But that doesn't help anymore, it just renders holes in the layers and instead you see a lot of pink XD
Is there something I'm missing?
Here have the CC3 file as well.
/Calle
While its a bit difficult to see with the very busy and quite similar textures you have there, this is Transparency Acne.
Try adding a new sheet between the two sheets these textures are on and see if that stops it. Sometimes it does, and sometimes it doesn't.
It didn't work on this one. But I got it to work with a backing sheet instead. For some reason the usual purple didn't do the trick. Sometimes you have to try different colours.
Is this the only way?
Couldn't this be something a patch could solve? Work arounds are great but they should only really be used until a patch of some sort fixes whatever it is that causes this. =)
Also Thanks again Sue! You're a champ! <3
You're welcome :)
This is one of the only ways for now.
There are possible solutions in the pipeline, but they are quite a long way ahead just yet.
