Weird issue with symbol scale
I just revisited my Tilkar map and discovered the map with plenty of red crosses. The mountain and hill symbols gone! Used the Symbols Manager to import the PNGs and voila, all them came back... but way smaller than before.
I used a different size for all them to fit the map as i wanted. Is there any way of rescalling all them without the rescale option which moves the symbols off their positions? Thanks in advance.
Symbols can be rescaled from the symbol manager, that will affect all the instances of the selected symbol in the map. That won't affect the position of the symbols (The symbol's origin will be the center of the scaling).
ah thanks, will try it.
You can also use the Symbols > Scale Symbols in Map command from the menu to scale symbols centered around their point of origin, if you don't want to affect their default size.
Well, i actually manually changed the size of the symbols to fit my pleasure, so im afraid it wouldnt help. Anyways, it´s solved now. Thanks Ralf.
