Alternate Pallet / Mappa Harnica
I created maps with an alternate palette (Mappic Harnica), but a reload erased the palette and now the maps I created do not load correctly. They have purple where the alternate palette was. Any idea how to get the old maps to reload with the orignial alternate palette? Ihave copied the Harnica Palette already in the Altenate Palette File in the program. Did not work.
    Did you attach the palette to the drawing (File -> Drawing Properties -> Attach to drawing)? I've seen some cases where the palette resets if it isn't attached. (Note that attaching stores the palette as it is at that moment, changes at a later stage means it have to be attached again)
  • 1 year later
  • I followed the instructions provided by Roy Denton and Loopysue.
    The palette does not change.
    PALLOAD
    right click on the drawing to open the dialogue box
    find Harn.pal in the CC3+ file
    left click to attach
    Open File/Drawing Properties
    Click on Attach to Drawing
    Click Ok
    Save Map
    Re-open map
    Harn.pal not attached. Palette has not changed.
    What am I doing wrong?
