FT3 output to COS3
Problem. FT3 outputs an icoshedral map, which is great for letting peeps create their own globe or, theoretically, for mapping back into a COS3 Traveller map. It also produces a range of views for input to COS 3. Problem is, I have a fair number of overlays on a FT£ world that I want output to COS3 Trav format, but I can't work out how to output them without using the icosohedral output...
...which doesn't match up with the templates. What I get is on the attached, where the FT3 output overlaps the template at one end. I can't work out or see any way of altering the output or template in either programme.
How can output the file with overlays, or set up my own/modify the existing templates, or even get any output/template params correct?
Cheers for your help.
I use 'Export World -> Cosmographer template.
I don't get a result like yours. I have FT3 3.0.21
Did you resolve this issue?
