How to set drawing tool's drawing method?
I find the way to set drawing tool's drawing method is inconsistent, or maybe I've done it wrong.
I can set drawing tool (e.g. landmass) using the dialogue box to be poly/fractal/sketch etc, but how can I set it to be parabolic curve? I've seen it briefly mentioned in the Dome, but cannot find more of it.
    edited June 2020
    Unfortunately, drawing tools doesn't support all the various shape options out there. For smooth polygons, it only support the standard Cubic B-Spline
    The available options for drawing tools are all found by hitting the Options button after selecting the appropriate method from the dropdown in the draw method section.
    I guess you can probably make a macro drawing tools that calls upon the parabolic polygon (PSPOLY) or path (PSPLINE) though.
    edited June 2020
    Hi there! Straight/smooth is a property of the path or polygon you are drawing, and as such not a new "Draw method". Choose Path/Polygon from your draw method, the click the Options button to set your tool to "Smooth". You'll now be drawing cubic paths or polys (CC3+ default method for drawing smooth lines).
    True parabolic lines can't be drawn via drawing tools (short of doing a macro), for these you you'll have to right-click the Smooth Poly and Smooth Path buttons on the right-hand toolbar. FOr those interested, I've attached a quick reference image for the difference between the various types of smooth lines.
    EDIT: Ninja'ed by Remy.
  • Hi Monsen and Ralf, thank you for your answers.
    The reason I ask is that sometimes I can use parabolic curve when using drawing tool to draw landmass, sometimes I cannot. I wonder if it is the clicking order I do to the landmass drawing tool. I think it might just be by luck when it can and when it cannot.
    Thanks for the diagram, Ralf. I think you can see it somewhere within CC3 but I always forget where. It's a useful reminder that if you don't like the way one type of curve behaves you can always try one of the other two. I have a personal preference for the Cubic B-Spline, but that's just because its the closest one to the curves I used to draw in my Corel Suite 9 software before Win 10 killed it.
