Symbols for map created in SS5
I have lost my Cities of Schley buttons for the different types of Schley Symbols.
I had just installed all the Annuals to my PC and upon creating a new map in the Cities of Schley style, I had the DD3 Buttons. so I clicked CD3 and just got the CD3 Buttons. I have been able to navigate to the SS5 Symbol Set and open it but I now have to scroll through the entire catalog to find the symbol im looking for.
I feel I have just missed something or I am being too picky - but I loved those buttons !
thank you for any advise
Q
"Darren"
Q
"Darren"
Is there a button just for SS5 in the row with DD3 and CD3 ?
I was also wondering about the order in which I installed everything. Is there a proper order to install the addons ?
Thank you
Quayuaze ( Darren )
If buttons are missing, you can try closing down CC3+ and running the CC3menuconfig.exe file found in the CC3+ data directory. (It runs completely silently, without any messages)
There is no required install order. Only important thing is that you already have CC3+ itself installed before installing any add-ons, and that you (re-)install the latest update after you are done installing add-ons.
Here is my install order and notes:
Installing to new SSD C:/ drive 2TB so plenty of space. (Anti- Virus [BullGuard] is off PC Not connected to the network.
CC3PlusSetup394
CC3PlusUpdate25
At this point buttons for DD3 & CD3 show up while not yet installed (???)
CD3setupForCC3Plus
DD3setupForCC3plus
SS1SetupForCC3Plus
After the install of SS1 had this error - FastCad: Menu File not found-
CC3PlusUpdate25
Buttons Back ! Seems all is OK
SS2SetUpForCC3Plus
Had to validate registration -Done- then open CC3+ and no buttons -FastCad: Menu File not found-
CC3PlusUpdate25
Seems to be running fine
SS4setupForCC3Plus
All is OK and the button for SS4 has appeared
SS5setup
CC3PlusUpdate25
No change
CC3PlusUpdate25 a second time
No change
Then thought about CC3 menuConFig.
Found it and ran it as administrator - - no buttons -FastCad: Menu File not found-
To sure what my next step should be ? At least I have what I did from a fresh install for some one to look at.
Thank you very much for all your help and time.
Quayuazue
(Darren)
I think your best bet is to just contact support and have them resolve this for you. The tech support form is available by logging in to your registered users page.
I did notice that you mentioned your PC was not connected to the network. It might be useful to be connected when installing the components, as they do fetch the newest menu configuration file from the internet if possible. I don't know if that will help you, but if possible, it might be worth re-installing update 25 while connected so it can do that.
Thank you
Darren
Would it be necessary to go back and start with my old old cd and install all the upgrades.
Wanted to ask here while Mark at tech support is trying to figure out what I have done to break things...lol
Darren
The exact same result for this computer as well. Is it possible that my down loaded installer is "bad"? lap top and desktop having the same issue seems weird … no ?
Darren
Ralf has sent a new Download but I am having the same issue on both computers … might have to restore them both. ? I feel it has to be some thing I have done for this to happen on both pcs.
sending results to Ralf "the Pirates Cartographer" (lol) and ask about if I should do the restore.
Q
Darren
Solved !
I had a tech friend look into my OS settings and check if there was something on my end fouling it all up.
My account on the computer (the only one) was not set as an administrator and the windows defender firewall was not turning off as intended because I was not an Admin. My AV turned off normally and I did not think about Windows firewall becoming active.
I am sorry for all the head ache I have caused. Thank you guys very much for all you help with this issue. Thank you for such a wonderful Program ! You guys & gals are the best.
Thanks again for everything
Darren McDowell
Now have fun mapping
