Maze for bored kids
Here is a maze I made the other week for bored kids, based on the recent Inked Dungeons annual. I had to turn it on it's right hand end to get it on the forum at a readable size, so you might want to download it and turn it 90 degrees anticlockwise!
The rules are:
- DO NOT POST THE SOLUTION!
- Start at either end to get to the other
- You can only cross the lava streams by bridge.
- You are dead if you fall into the Spider Hole, which is a polished obsidian ventilation shaft that goes right down about 100 miles to a hollow earth situation.
[Image_14436]
Have fun!
The rules are:
[Image_14436]
Have fun!
Now only throw in some wandering monsters, some treasure, and you've got a game.
Dream - I don't know. I don't actually play. I enjoy making the maps for others to use.
I have a feeling that this particular map would be rather low res because I reduced it's size to fit the forum rules, but I can provide one that is larger if you want. Monsen might be able to help you with how to set it up - or any of the DMs who drop by here from time to time.
