Fill style being placed without being selected
I don't know what happened, but I was working on a fill style and now when ever I draw any kind of poly it fills with that fill style automatically. What did I do and how can I fix that?
All polygons are filled with the currently active fill style, which is listed at the status bar following the FS: indicator.
If you have a bitmap fill active, and the result don't match what you think you have chosen, open up the fill style dialog, and check the path to the bitmap file there, perhaps you have changed one of the existing fills into your fill instead.
You'll also want to make sure that the sheet you are drawing the shapes on don't have a texture overblend effect with your fill specified.
