Sheets not Deleting
For some reason I cannot delete sheets from my map, but I can add/REname, hide, reorder, Show all, and Hide all them. This doesn't seem to do any harm, but I like to delete sheet as I determine I have no use for them, for instance Contour Sheets since I make my own named as CONTOURS 100m and so on. Nothing appears amis on the Layers display.
I created a new sheet and immediately tried to delete it and nothing happened.
Then I closed and restarted CC3 and LO! It worked again.
While gratified, I sort of hate it when things like that fix problems. Who knows what is lurking in the depths of the code?
Hide all of the sheets you want to keep, then zoom waaaaay out. Era the area that includes the map, the sheet should then be gone.
However, you shouldn't need to delete that point to delete the sheet.
All other times when I delete the sheet in the sheet popup, it is gone.
Are you refreshing the map with ctrl-r after deleting ?
