Map Boarder
Hi all,
I have been working on a map for a while now and I can not seem to get the background and rivers to end at the boarder.
not sure what I have done to change this. hoping some one can point me in the right direction to correct this.
thank you
Q
thank you
Q
The SCREEN sheet normally contains a white polygon right outside the border which covers up anything extending beyond it, like your rivers.
It is easy to set up again though, just create a new sheet, put it near the bottom of the list, right above MAP BORDER, and draw some white polygons on it. Use Snap to ensure you draw it right at the border.
Will make that sheet ASAP
Thanx again
Quayuaze??
