Moving Room Nodes (adjusting a wall/room)
Greetings!
Long time no map!
I'm working on a floorplan for my group's mansion they're having built which is based on a real-life floorplan one of the individuals found.
I need to turn the "garage" into a stable, and the garage is too narrow, so I need to adjust the wall/floor for that space.
How do I select the portions of the wall/floor that need to be adjusted?
In AI, for instance, I could simply select the nodes that need to be shifted and move them where I need to. That doesn't seem to be something I can do here.
I'm using DD3+ with Schley's SS4 for this particular map.
Thanks!
Jon
Long time no map!
Thanks!
Jon
Lovely to hear from you again
You can only move them one at a time, using the move node tool on the left hand toolbar. If you need to move them a foot, turn the snap grid on and use that to position them accurately.
(then you have to right click to confirm it I think)
If you are trying to edit a multipoly (you will have to explode it and then redo it after you've finished editing)
If the poly is on a frozen layer.
Doh!
