Extra large doors
Is there a way to scale doors up? I want to add some giant doors to a map breaking a wall with 50ft wide double doors.
    You can scale symbols by right clicking and entering a specific scale from your keyboard in the popup menu, or by holding down the CTRL key on your keyboard and moving the mouse until the symbol is the right size.
  • You might want to create your own custom door symbol if you want it to look realistic. Existing classic door symbols are typically 5′ wide (10′ for a double door) and 3.5″ to 6″ thick (not counting door handles and rivets for metal and re-enforced doors). The door panels are all solid; while this might scale up reasonably for stone and metal doors, wooden panels should be made of multiple boards (unless 25′+ diameter trees are common in your game world ;) ). You might also want to reconsider why you want regular swinging doors that wide. They would require a 25′ swing arc to open fully and unless this is a home for giants (which it could be I suppose) a drawbridge, portcullis or sliding door (horizontal or vertical) might be more practical.
