Effects not showing
I've a problem with sheet effects. I set up my effects (based on CD3 bitmap
but when I turn them ON some of them are showing and others not. The strange thing is that the effects not showing correctly are different from time to time.
I briefly searched the forums for a solution but I was not able to find anything. Any ideas or workaround?
Thanks!
Thanks!
If it is on the wrong sheet, you can move it to the corret one by *right* clicking the Change Properties button, select Move to Sheet from the menu that pops up, select the entity or entities you want to move to the correct sheet, right click and select Do It, select the correct sheet from the Drawing Sheet list and click OK.
Well, I an currently at work and don't have CC3 here ;-) so I can't check. But I remember the map being 1250x750 or so (metric) using the CD3 bitmap B style for effects.
Anyway, as soon as I get some free time I'll check. Thanks
Sadly this week is a real mess for me and I have no possibility to open CC3 until friday. So please excuse me any delay if you answer.
Thanks
