resizing the map when finished
Hi all,
is it possible to resize a finished map (from 300x200 pixels to 3000x2000 pixels f.e.)?
If yes, how is it done ?
Thx a lot
    The size you are talking about is the size the map is exported when you render it to a bitmap - jpg/png/bmp etc.
    You can adjust the size of the output to any size you like (within reason, since enlarging it to the size of an entire wall would cause the bitmap symbols to look a little pixelated), by clicking the Options button at the bottom right hand corner of the Save as... dialog.
    To get rid of the white border you can use one of the Save As... Rectangular section options, and make the rectangle size the same proportions as the map itself, then pick the corners of the map to define the area to be rendered. Best quality is png. Smallest size in MB is jpg. If you want to use jpg I wouldn't recommend going any lower than 85% compression, or you will get very visible artefacts in the image.
