Macro button: visible in all menu and toggle style
Hi !
I have two questions regarding button macros:
1. Is there a way to create a button that will be visible in all menus (CC3, DD3, TT1, …) without adding it to all *.mnu files ? In other world, is there a 'master' menu ?
2. Is there a way to create a toggle button, similar to the buttons that are at the Bottom right (Snap, Grid, …) ?
Thanks for your help
2. No
But unfortunatly, creating this file prevent CC3+ to launch
I created the file fcw32.imn in the Data folder.
If the file is empty, CC3+ launch correctly.
This code is working in a *.mnu file:
#434,@Bitmaps\Icons\miscellaneous.bmp:[Toggle Sheet Effects]{}|FX;
But if I paste it in the fcw32.imn file, the CC3+ won't launch.
Does it need some special things in this file ?
Basil
Thanks a lot !
