Installing symbol set 1
How do I know if i properly installed Symbol set 1? Im not seeing any new symbols. Can anyone help?
  • edited August 2009
    Right click on the toggly symbol styles button: sympath.gif
    You should get a menu with several SS1 styles.
    If that doesn't work, use the button I have marked with red in below screenshot. You can then open symbols manually.
    image.php?AttachmentID=394
    The symbols are located in this directory:
    [wherever you installed]ProFantasy\CC3\Symbols\Maps\SS1
    There is no button in the list next to CC3, Pro, Cosmo, etc. Same for Symbol set 2. There is one for SS3.
    The best way to check for a correct SS1 install is to start a new map:
    - New Map > Map type: Overland Maps (decide settings myself) > Map style: Ss1 Fantasy A
    - after saving the map, clicking the catalog buttons should load the symbols in the Fantasy A style, and the drawing tools should bring uo the corresponding tools.
    Hope that helps,
    Ralf
