ToUM Update & Cover; CC3 activation
Hi,
I just purchased the Tome of Ultimate Mapping and have the following questions:
1-Why were the front and back cover not included?
2-Is there any way to get them? (I can see a thumbnail of each in the product page in the website, but no regular/high resolution)
3-Are there any news as to when will a new (revised) version will be released? (mainly updated for CC3, CD3 and DD3)
Also, I will be purchasing CC3 shortly but have the following question:
It is my understanding that the product requires an active internet connection during setup to verify it's legitimately licensed.
I don't have internet in my home computer (where I'll be installing the software). I will download the software at a friend's house (he does have internet), but don't want to install it and activate it there.
Is there any alternative way to get the software to work?
Thanks,
pool7
    edited August 2009
    1+2) The front cover of the tome is included as a separate pdf file. You'll find it inside the same directory as the tome itself. As far as I know, there is no way to get the back cover.
    3) No news yet. It is probably still a far way off.
    As for CC3 activation. If you install it on a computer without internet connection, it gives you a code that you must bring to a computer that does have an internet connection, and enter into the ProFantasy webpage (Along with your serial if I don't remember incorrectly) (CC3 will tell you the exact URL and what you need during install). The website will then give you a confirmation code to be entered into the CC3 installer before you can continue.
  • pool7pool7 Traveler
    Thanks a ton for your quick response (especially for the CC3 activation information).
    I only have the tome right now; no other PF product. I know that's the reason why the support (sample) files that come with the tome did not get installed; however when I check the installation folder (C:\Program Files\TUM) I only have one PDF file (eTome.pdf) which is the tome itself (no other file with the cover).
    So, here are my questions to the PF team:
    1-Are covers really included with the PDF (download) version? If so, how would I go about getting them?
    2-If I had CC2 Viewer installed, would the installer have detected it and installed the support files?
    3-When I purchase CC3 (in the near future), will I have to reinstall the tome in order to get the support files?
    Thanks in advance,
    Regards,
    pool7
  • 1.In the C:/Profantasy/CC3/Documents/Tome folder I got
    eTome.pdf
    Sudbury.pdf
    Sudbury_example.pdf
    Tome Cover.pdf
    3.The Tome is yet CC2 not CC3. Which support files are you talking about ?
    That's odd and makes no sense.
    Why wouldn't the I get the Sudbury.pdf, Sudbury_example.pdf and TomeCover.pdf?
    I can only think it's due to the fact I don't have CC2/CC3 installed; but c'mon ProFantasy, these are PDF files!
    The support files I'm talking about are the ones mentioned in the product page: http://www.profantasy.com/products/tome.asp
    "The Tome includes over 50MB of support files; example maps, symbol catalogs, tutorial files templates and style packs."
    Anyway, I'll try later to uninstall it, then install CC2 Viewer/CC3 Viewer (I'll try both) and reinstall the Tome; maybe that way I'll get all files.
    Thanks for your help! ;)
  • Now that you mentionned it I remember having tools.
    Yes I think you cannot see all because you dont' have CC3.
    Have you checked if any profantasy folder has been created in the install process ?
    I did check within C:\Program Files but found nothing (have WinXP SP3)... maybe I'm looking in the wrong place.
    I'll still try later today and post results.
  • Posted By: pool7maybe I'm looking in the wrong place
    Don't think so. Have them in C:\Program Files\Profantasy\CC3\...
    If you have XP SP3 (as I do) it's easy to check. Click START, SEARCH, all files, *TOME*.*
    I guess everything comes from not having CC3 installed. The install exe probably checked for those folders and as it didn't found them... I think the whole thing was to buy CC3 first and the Tome afterward.
    All the support files are basically useless without CC2/CC3 anyway, so it makes no sense in installing these. It is a bit strange that the other PDF files weren't installed though.
    Shoot me an email (ralf@profantasy.com) and I'll be happy to set you up with the missing pdf files. I guess it never occurred to us that someone would be using the Tome without having either CC2 or CC3.
    I just sent you an e-mail Ralf; thanks for looking into this.
    I tried with both CC2 and CC3 Viewers but these are not detected by the ToUM setup program.
    I'll be purchasing CC3 at the end of the month/beginning of next month, so it's not a big deal.
    I know it's not very logical to get the tome before getting the software, but what can I say? I love ebooks (and cartography) =P
