Blank fills on Cosmographer deck plans
Using "Pick a pre-defined template," "Cosmographer Deckplan Bitmap 250 x 200," when I right-click on the Draw Hull tool, I get a lot of blank entries. If I use one, it works, but they all seem to use the same plain gray fill color. If I "Decide Settings Myself" I get images for all but one show images, but about half of them look (and draw) the same as "Hull, Battered."
I've reinstalled Cosmographer and update 19 (both as administrator), with no chance.
Is this something anyone else has run into, or should I contact tech support?
You can fix this quickly by importing a map created from the wizard template into the map based on the fixed template, and immediately undoing the import. That will leave the additional bitmap fills in the map. I'll also fix this in the Cosmographer setup here.
You can fix this quickly by importing a map created from the wizard template into the map based on the fixed template, and immediately undoing the import. That will leave the additional bitmap fills in the map. I'll also fix this in the Cosmographer setup here.</blockquote>
I'm having this same issue. I realize this probably makes perfect sense to you, but for us neophytes, could you explain in a bit more detail please? Thanks!
