Community Atlas - Alarius - Northern Scar Environs
One of two caves in this area I am going to (try to) map.
I decided to work from the northern most of the two caves and started by mapping the area outside the cave first. Map is 80 x 50 with no effects applied yet.
There was a lot of erasing and experimenting, as I tinkered a bit with symbol scale as I placed the mountains. I felt the default scale for them was too small, so I varied the scale a bit with each mountain. I also tried to mix up the mountain symbols as much as possible.
You can see it here
You can see it here
The area in question can be Seen here
The resolution is better here than on FB, so its worth trying again
High Resolution here
Nice looking map. I'm looking forward to the story
