Creating your own tools
 Topdecker
                Traveler
Topdecker
                Traveler
                    I would like to create my own floor tool.  Sadly, beyond having created the graphics, I don't really have a clue about how I build my own tool inside CC3+.  If there is a discussion, tutorial, or document explaining this, I sure would appreciate being pointed to it.
Thanks!
Top
                            Thanks!
Top
http://rpgmaps.profantasy.com/?p=4406#more-4406
A more detailed breakdown of everything can be found in the Tome (if you have it) on page 118
Top
Where the Tome is concerned, I usually browse the index, or CTRL+F and a single word, then click next till I get one in the right context.
The bookmarks also work well if you work down through the hierarchy in a logical fashion.
DPI settings. I have scaled all my image work to 72ppi/dpi. Does CC3+ care? If so, what dpi/ppi settings are needed? I've already had plenty of frustration with this
The 4 image resolutions. I read that CC3+ will take your source image and create the lower resolutions automatically which is fine. However, it doesn't really explain what scale to use initially. 40 pixels per foot is what I am working with for dungeons, but upon reflection, it may not be enough. What is a sufficient pixel density for battle maps and such?
Thanks in advance!
Top
Playing around with floor tiles...
Top
Top
If you create a file the size you want for your tile, then hit the W key, the tile becomes an infinite plane of tiles of itself, and every mark you make on it is repeated on all the adjacent tiles - lines and marks that cross the edge do so seamlessly. It takes a bit of getting used to - seeing a straight line coming back to join with the end you are still drawing, but its far better than all these other 'make seamless' operations I've seen in apps like GIMP.
When the infinite sea looks about right you can hit the W key again and be left with the perfectly seamless tile you have just drawn.
Top
Also, is the goal of texture files generally to act as seamless tiles?
Just trying to learn the ground rules before I invest more time and effort
Thanks
Top
