Copying an entity from a drawing to another
I know this has probably been asked before but the search in the forum is all but useless.
I've been trying to copy an entity from a drawing representing one level to another drawing representing another level. I need the entity to be copied exactly v(coordinates, sheet and layer).
So far, I've not manage to find the trick to do this.
Thanks.
Thanks.
1. Use Copy from the Edit menu.
2. Select all the things you want to copy, and right click then 'Do it'
3. When you are prompted for a copy origin (command line) type 0,0 (zero comma zero), to pick the origin at the bottom left corner of the map.
4. Use Paste from the Edit menu.
5. When you are prompted for a past origin (command line) type 0,0 again to paste the copy in exactly the same place as it was in the first map.
A little unstable but I eventually got what I wanted.
Thanks for the quick response.
