Text character limitations
Is there some reason why the amount of text in a multi-line text field is limited to something less than 200 characters?
When adding room/building names in a legend or a shortish description of the reason for then map, I find I often have to add multiple text fields to display the text.
Attached is an example of a map I have just finished, and the level description is in 3 different sections.
And can you specify the display font?
Fonts and placement is as normal for adding text.
I've been using this software for over 2 years now, and I've never even noticed that button!
Thank you
Sorry Joe!
I was thinking about this a lot in the context of your map since the possibility came to light, Jerry, since yours is an Atlas map, and I decided it was probably for the best that you had worked to add the text in the usual way rather than referencing it.
I'm definitely using it for non Atlas maps, though, since it really beats having to chop everything up into small portions and then stick them back together in what hopefully looks like a continuous block of text.
