Change grid co-ord origin
Is it possible to change the numbered grid co-ordinates so 0,0 isn't at the bottom left? And in the same vane, change the counting order? I'm trying to do a grid overlay on a map, but instead of 0,0 being in the bottom left I need it in the top right, so it counts up going right -> left and top -> bottom, instead of left -> right and bottom -> top.
Also while I'm at it, how do I make the grid lines thicker?
Thanks
Thanks
To make the grid lines thicker, simply use change properties on them. With groups unlocked, you can affect individual lines, or with them locked, the entire grid. (You may need to unlock them to give the outer border special treatment)
On the number thing, I click on 'Numeric Edit', and it prompts me to select the entity to edit, but no matter what I click on it never seems to register it and just goes back to the command prompt [within the program].
Check your layers and see if they are frozen. Click on the thaw all button. Then click okay to exit the layer popup.
Ok, so i have to edit each number individually. Labour intensive but better than nothing.
