Changine the view causes entire map to disappear
Here's a strange issue.
This only started about 3 days ago. I'm working on a new CD3 map and sometimes when I change the view in any way (zoom in, zoom out, move the sliders, etc) the entire map goes white. The map appears to still be there, I just can't see it. The only solution is to reload the map.
Fortunatly, even when the entire map is white, I can save the map and then reload it so I don't loose any work but this is really frustrating. Any ideas?
Running Vista 64-bit, Tablet PC with CC3, DD3, CD3 and Annuals installed.
Click on the pencil eraser left side of CC3. Do a square select area almost up to the map border. If you select any entities, right click and select Do It. That will erase the entities outside the map border.
Say the map is from 0,0 to 800,600. A point at -15000,-9000 will yield what you got.
So I am zooming in and out and the entire city vanishes...
What always works for me:
Closing CD3 and starting it again. Pan to another part of the city and zoom in and out from there.
Thanks for your suggestions though!
(and have I mentioned how much I LOVE this software? I'm now making maps for no particular reason at all. Just because I can)
One of my players has said he's interested in running a game. My response: "Can I make the maps for you????"
I'm gaming with my kids to make more maps!
Just some thoughts, hope something helps.
I have just been drawing sea contours and had to scroll to the right to continue drawing when the same behavior reoccured - every layer/sheet disappeared, although my sea contour (unfinished) was still active. Of course, without seeing the land I had to quit the drawing of the contour and the piece that i had drawn was visible - everything else was not, however.
Zoom extents once again moved the map view to the most extreme bottom right and I could not get the sheets to show up again and had to quit out and reload.
Instead zoom out, then uyse the zoom window to get to a smaller area.
