Effects Rendering - Screen Flashing and Blue-Green Tint
So I've got two issues when turning on effects.
The first one has been happening for awhile, but I have a work around for. I suspect it's the size of the map and number of entities, but not sure. When I turn on effects, CC3+ always goes to a green background and every 20-30 seconds the map image flashes and returns to green. This seems to continue indefinitely (at least 10+ minutes) unless I right click on the Sheets icon and select Effects On a second time. In which case it then flashes one more time and then renders the map with effects on. Any ideas on if their is a way to solve it?
Number two just happened (same map). When I turn on effects, the whole screen (beyond the map borders if I zoomed out) gets a blue-green tint to it. I don't think I have any effect that would do this, but it might be an issue with a Glow effect. But, I've tried hiding all sheets to see if I can isolate it. But the issue persists. I went back to an autosave map and it does not have this issue. Have tried exiting CC3+ and re-opening the map, but it still appears when I turn on effects (using workaround above). Any ideas?
I don't have a fix for the first issue unfortunately, happens to me too sometimes on complex maps.
Sometimes effects go in the wrong place - especially when you have just created a new sheet and there's nothing drawn on it yet.
Effects should by default be added to the Selected Sheet. If you click the Whole Drawing radio button there shouldn't be anything there. If there is, then delete it.
I have also thought about deleting the most recently added sheet and seeing if that helps.
I can delete every sheet but one, and the effect remains. I've tried leaving behind several different sheets as the last one, and the effect is still there. But, as soon as I delete the last sheet it goes away. I've also added a new sheet, and deleted all the others and it goes away.
I'm going to keep exploring, but if anyone has any ideas, it would be appreciated
If that does not help, please post your original drawing FCW file so we can take a look at it.
If when you add a sheet effect and it doesn't appear in the Selected Sheets panel, don't just assume it hasn't worked and try adding it again. You need to check that it hasn't sneaked off to the Whole Drawing panel.
If you find it on the Whole Drawing panel delete the effect (not the sheet).
If you are having trouble trying to make an effect 'stick' to the Selected Sheet its quite likely because there is nothing drawn on that sheet (that's when it always seems to happen to me). What I do to get around this problem is create the sheet without any effects, close the dialog by clicking OK, then go and draw or paste something on the new sheet. Once there is something on the sheet I go back to the Drawing Sheets and Effects dialog and start adding effects.
I feel ... almost stupid
So, I thought the "Whole Drawing" radio button was per sheet. So, I had looked through each sheet to make sure the "Whole Drawing" button wasn't checked. Which I now know isn't the way it works. Instead, I just needed to toggle on "Whole Drawing" and check the effects there (those that are not related to a sheet).
Thanks everyone, sorry for taking your time
Anyway, PEBKAC was the problem. I'm a big boy, I can admit it
I get that ALL the time :P
