CC3+ Won't open
Hello,
I hope i'm posting this in the right place, I'm fairly new to the forums. I have been using CC3+ for a bit over a year off and on. I have been designing a map for the last three days for an upcoming campaign. I finished working on it yesterday and saved my progress and shut down my laptop. Today when i started it up and tried to open CC3+ it will not open. When i click on it i get the little circle indicating activity but then it goes away after a minute or two. I have tried the following this:
Restart
Run as administrator
Windows Troubleshooting
I am running windows 10
Any help anyone can provide would be greatly appreciated, i'm on a slight time crunch to get this map finished. Thank you in advance.
Tony
Restart
Tony
Note that if that works, and you last worked on an important map, immediately go to file -> open autosave drawing to get hold of your autosave before it is overwritten in case you need it, and then save this as a new filename somewhere save. Since CC3+ only keeps one autosave, it is important to get a hold of this before it is overwritten with a save from a test map.
If starting with another map doesn't help, it might be a corruption to your configuration file. Try renaming the CC3PlusCfg.xml file in your CC3+ data directory, and then starting CC3+. If that works, we'll see about fixing or replacing this file, as you don't want to be running with the new blank file CC3+ generated, but it will tell us if this was the culprit or not.
Do note that this is a community support forum though. For official technical support, go here.
