Black and White button from Export options
Hi everyone,
About a year ago there used to be a way to put a checkmark in a box so your map would change from color to black and white when you tried to export it. With the newest version of the export function, that doesn't seem to be an option anymore. How come that was taken out of the Export function? It was really convenient and it is one of the things I wish was left in when the new export function was created.
You can also apply a whole drawing effect, such as RGB Matrix Process to turn your map greyscale before exporting.
Ctrl-G for grayscale, and under Image -> Decrease color depth, you can select 2 colors. Click okay, and it changes. Then save as a different file.
