Inner Drop Shadow
This might be a silly question, but is there a way to create an inner drop shadow on a smooth polygon? I've been playing with the various sheet effects to no avail. Either I'm missing something terribly obvious or there is no simple way to do this.
Do you have a screen shot of what you are trying to do?
https://cdn.shopify.com/s/files/1/0184/8744/products/LakeTahoe_24.5x31_-L_1024x1024.jpg?v=1350867584
1) Create a polygon with a fillstyle using one of the transparent bitmaps (e.g., solid 20 Bitmap)
2) Apply a Drop Shadow effect to each sheet (Offset X: 0, Offset Y: -5, Opacity: 75%, Blur Radius 1 unit, effect units set to map units)
3) Apply an Inner Glow to each sheet for an overall outline of each contour (black, Opacity: 100%, Brightness: 75%, Blur Radius: 2 units, effect units set to map units)
This creates a very similar effect to Wyvern's method of creating a multipoly. The land itself would also have a drop shadow, although the Offset Y value would be 5 instead.
This seems to achieve the effect I'm going for as well. The resulting drop shadow on each contour is actually at the top and therefore makes it appear like it's actually a shadow from the contour above.
