Symbol Catalog Errors COS
Calibre
🖼️ 39 images Mapmaker
Recently bought COS and when attempting to use any 'sleek' deck bitmap, I get this error.
Help please
thanks
Cal
Help please
thanks
Cal
If someone else created the map and sent you the FCW file, then you don't have the symbols or fills loaded, or loaded in the same location as the map is looking for them in.
Will try to find the actual template name.
Still looking but fill style is hull_sleek_silver #267, list says.
Template: Cosmographer Deckplan Bitmap 250x200 I believe it says
thanks for the help, guys
Cal
thanks
Cal
I did check the template, and the sleek tools work for me, but if you can upload your map here, I can have a look at the actual fill references in the map to see if they are ok. If they are, you should probably do a repair install of Cosmographer, followed by a (re)-install of the latest update, since that means you are probably missing files.
