Creating a very large city
I am creating a city that is basically 20 miles x 20 miles (105600' x 105600') and those measurements seem to be too big for CD3 so I am going to go and start my city in the overland wizard, but just use the CD3 tools. Are there any pitfalls I should be aware of before doing this?
Just make sure not to use bitmap fills for houses on such a large map, or you'll probably run into very long display times. I'd recommend a vector style template, if you want to create individual buildings.
If you measure your map after thsi (or look at the coordinates), you will see the map size is actually correct.
I sketched out the city on paper, or in cd3, then put a square overlay over it. Breaking it up into smaller areas.
Then I draw, in CD3, each smaller area. I put them up on my web site linking thumbnails in html so the viewer can see how they go together.
I started drawing it, and that is what I am going to do Jim.
