Specific Selection of Objects
So...
Lets just say I have two objects. The exact same shape on the exact same sheet.
Is there a way to select one over the other?
If everything else is the same, you can also use the Entity Tag # (use list on them first to find the numbers), then use this number as the selection criteria.
More about selection criteria in this article
Life saver as usual and that's going to be some bloody useful knowledge.
