Another newbie question!
Here is the scenario. I am making a map with DeRust and I would like to use the terrains from Herwin Wielink, but they don't seem to be showing when I select and load his symbol catalogs. What in the world am I doing wrong!
Thanks!
Thanks!
Easiest way to do so is to
1. Create a new map in the Wielink style and save it
2. Go back to your deRust map, and use Draw -> Insert file. Pick the new Wielink map and hit open. Once you return to your map, before actually inserting the map anywhere, simply hit Esc to stop inserting. This will have resulted in the fill style definitions from that map being inserted into your current one.
Thanks!
