Trace Command not tracing correctly
I am making a regional map from a larger map. I copied part of the landmass from the larger map to smaller one. I went to trace it and its not tracing correctly.
The Green land mass is from the original map an the brown is the new. It is not tracing correctly and I don't know why
It makes me think of the way people use the GIMP select tool - clicking around the shape at various points - GIMP interpreting the contour to follow between those points.
Dogtag did a really good video about using the trace command here
http://forum.profantasy.com/comments.php?DiscussionID=6724&page=1#pgtop
If you are already 'doing it right' please excuse me for making the assumption that you *might* be doing it more like a GIMP user would do it!
And other than that I've no idea what could be causing it - sorry!
Also, it seems like you want to trace the entire thing? If that is the case, it is usually simpler to just make a copy of the original entity, and change properties on it (or use change like draw tool), or even just modify the original entity if your intention is to replace it.
FWI, I sometimes get the same trace results as you are showing, JoeyD. Sometimes its a matter of trying to trace a fractal polygon with a smooth one or vice versa. And other times its just a mystery (too many nodes or errant, maybe?).
@ScottA I tried tracing with both smooth and Fractal and got similar results
@Monsen It is attached
