Creating Grids With Variable Angles
I'm working on grids in DD3 -- but I'd like to be able to create per-room grids at variable angles, so that if you have (for instance) a 30 x 40 room at a diagonal I can see easily that it is 3 10' squares by 4 10' squares. Anyone have any good ideas how to do that?
I think you can trim grids.... but I've never done anything like that before, so you might need someone else to make either a better suggestion, or to tell you how you might finish the job
I've never even used a symbol fill, so I wouldn't know if doing such a thing would even work
Having drawn the one bit of grid you could then copy it and paste it, then rotate the different copies as required?
Not to fret, it's easy to determine the angle of a room (polygon). To determine the angle of any given line/path/polygon side, click Info>Bearing from the menu bar and then click the line/side you want to measure.
To apply the grid to an existing room, you can copy the floor to the grid sheet and then change the fill style to your custom grid. Another way is to create a drawing tool (see Joe's video) and then use the TRACE command to trace the floor.
I hope that helps.
Cheers,
~Dogtag
