Schleyscapes kickstarter - importing into cc3+
                    I backed the kickstarter a while ago, and now I would like to import the png symbols into my copy of CC3+.
He linked to this instruction page:
https://secure.profantasy.com/cchelp/SYMBOL/Creating_and_importing_PNGs_and_Bitmaps.htm
However, I have not done this before and I think I need a slightly more basic instruction set.
He has four different types of objects in the .png set. Creature, symbol, texture and token. Tokens have quite a few subcategories, but all are objects to be places on a dungeon map (some are landscape details but I would say they are better as the exterior of a "dungeon" map vs. an overland symbol.
Names are pretty long, for example: SS_001_Token240_Object_Cauldron_large.png, and there are small, medium and large versions of each symbol.
There is only one creature (spider bear) and only one symbol (secret door) and only three textures.
I am not sure how to figure out the exact scale used.
This is my first attempt to create a catalog / symbol set so I am a little lost.
Even steering me to a tutorial or good but much smaller example would help as I am not sure exactly where to start with it.
I used Joe's video. The result is I can now click one of the Dungeons of Schley buttons and it opens a prompt for me to pick between the KS symbols or the standard. I will make a video of the process specifically focused on importing these symbols at some stage.
Here's the video I followed:
https://www.youtube.com/watch?v=s5Lhz-QLpX0
I recommend sorting them in folders based on symbol type, exactly how is up to you, this is just a way of organizing them.
I also recommend renaming them before importing, as having symbols start with the very nondescriptive 'ss_001_Token240_Object' string isn't very helpful.
For the scale, check them in an image editor, and figure out how many pixels per foot they are. For example if a symbol that depicts a small knife (about a foot) is 100 pixels long, then the images are 100 pixels/foot. If images vary, I would simply import them all as 100/foot and manipulate scale in CC3+ afterwards.
