Community Atlas - Evakyl Draconic WIP
Lorelei
Betatester 🖼️ 46 images Mapmaker
The village of Evakyl Draconic is home to a clan of Dragonborn living in the deep jungles near Kimbunga Springs on the isle of Malajuri.....
This is why I require the permission to distribute any custom artwork along with the atlas, so the end user don't have to run around downloading various different symbols from here and there.
And, yes, @Monsen, I think I did download the Atlas trees (they should have downloaded into the "user" folder, right?)
Because the atlas is supposed to work no matter where you extract it on disk, it is very important that maps uses correct relative paths to refer to the resources used, otherwise the map won't work when included in the atlas. The atlas version of the trees comes with symbol catalogs already set up with these paths so that the mapper doesn't have to concern themselves with these paths at all, they can just use the symbol catalogs provided and everything will work perfectly fine (As long as they keep the map in the 'Your Map here' folder. (The your map here folder can actually be renamed with no ill effect, as long as it isn't moved, but Resources must not be renamed).
The non-atlas version of the trees will only work if users have manually downloaded and installed the trees themselves (AND put them in the right location), which is why these cannot be used for maps to be included in the atlas.
I am so sorry my trees have caused all this confusion.
Sorry Lorelei!
Sorry Remy!
Its a beautiful map!
Note that this map uses custom resources (Sue's trees), so to view it properly, you should either download the complete atlas, or if you just want to grab the single map, you will also need to down the atlas version of Sue's trees. I generally recommend just grabbing the entire atlas, since that should work out of the box (Assuming you have the other products this map uses already installed)
