Unfractalize?
Just curious, is there a way to unfractalize something? What I'm thinking, specifically, is the Fractalize command. I've Fractalized all the rivers on one of my maps and I'm not sure now if I like them that way or not. It really isn't much hassle to redraw them all if I decide to go back to smooth, but I was just curious if there was a command that would do it?
When you're done, however, you'll still have a straight entity (path, poly, etc). To make it smooth again, right-click the Fractalise button again and then select Straight to Smooth (STC on the command line) to convert the straight entity to a smooth one.
On the other hand, you can also make a fractalized entity smooth, without removing nodes. Personally, I think this often looks pretty good with rivers.
Incidentally, you can also right-click the Explode
Cheers,
~Dogtag
So I have a filename01_001, save it, fractalize. I don't like the results, load filename001_001, fractalize gone. Much faster than deleting lots of nodes.
I do have filename01_001 up to filename01_050, for lots of my maps, but it goes back further than undo. So it can be helpful.
