Can Not Create Corridors
 LordEntrails
                Traveler
LordEntrails
                Traveler
                    CC3+ v 3.77 w/ DD & SS4.
Started a new dungeon map yesterday. I've put in all the rooms fine. Now when I go to add corridors, CC won't work as expected.
When I select the Default Corridor icon from the toolbar I get the Select Drawing Tool window (with the style set to SS4 Dungeons of Schley and filtered to Corridor, Default) Selecting one of the default corridors or one of the others (including one I made) results in what appears to a polygon room.
I do not get the Add Corridor Dialog or options to set corridor width as shown on pg 136 of TUM. I've done the SS4 and TUM tutorials before, but now things are not behaving. I've tried exiting CC3+ and still get the same behavior.
I notice that when I try a new map using a predefined template (one of the dungeon ones) I get the expected behavior. But, when I create a new map using my own settings and pick Dungeons of Schley, I get this incorrect behavior. I also noticed that with the DoS maps I do not get the Add Room dialog, it just goes straight into drawing a polygon.
So it appears to be something with my DoS style or templates. Any ideas or suggestions etc?
I should have knew it was PEBKAC!
Is that expected behavior? It's not that big a deal to click the DD icon every time but is their something (else) I'm missing?
If I get ambitious, I might just have to edit the macro for the SS4 template itself (since I probably will always prefer the DD behavior).
