Copying or Isolating Areas on Large Maps to Individual Maps?
Ok, so I thought I knew how to do this... but I was wrong. What I'm looking to do is to take each individual country from the large continent map I created and isolate them so that I can now go in and enlarge and detail each one with things like cities, roads, small rivers and other things which do not appear on a large-scale continent map. I know how to copy and paste items between maps, but that doesn't work for this. I want to either be able to copy or cut out chunks from my finished continent map and paste or copy them onto new maps for each country or just isolate each country on copies of the main map and delete everything else around it. Something so that I end up with individual map files for each country. Whichever is the best way to do it? I looked through both the Tome and past discussions here, but I'm not even sure what the technical term/command for this is, so I sort of looked around the best I could but found nothing that helped.
Large map to small.
Maybe I am misunderstanding, but is there no way just to cut or copy a block from one map to another? When I attempt copy/paste the cursor, of course, catches the whole of the land mass, so I end up with the entire map again.... Or to just cut/trim/delete everything back to leave one block of a map? That would work for me if I had to do it that way.
Cresta was done this way. A hemisphere with oceans continents and nations named And a few mountain ranges. Then a rectangular section of part of that of one cintinent. More details added. Then a kingdom on that continent. Now cities and rivers are added. Etc. That is how I did the northern hemisphere of Crestar.
I have made square and rectangular maps. It might be too difficult to make a map that follows the curve of a nation as long border that isn't a straight line.
Typed in using my cell pjone.
Not sure whether it would be easier to do the break/split/trim thing or just copy each country's border and symbols onto a new map and then put fills back in. Either way sounds like an awful lot of work that I hadn't expected but again is my own fault for not taking the whole CC3+/CAD thing into account earlier and stupidly relying on old standard art program thinking.
The whole procedure isn't that difficult though, but it does take a little bit of practice, but once you get the hang of it, it is usually pretty quick.
Also, note that an alternative to breaking and trimming, you can also use trace, that is pretty quick and painless. Generally, I use a combination of tracing and trimming.
I recommend having a look at the editing with drawing tools chapter in the CC3+ user manual, especially the trace section of it. It goes over the basics of how to create a detail map from another map, and if you have the Tome, there is a more in-depth tutorial there.
You can also make CC3+ do some of the trimming work for you ny using the cut menu. Just type CUTMENUON on the command line, CC3+ should give you a confirmation dialog, and after restarting CC3+, you will have a brand new Cut menu with some tools. Do note that when it cuts a polygon, it will be reduced to a line as I described above, the filled are won't reappear untill you turn this line back into a polygon with the path to poly command.
While it does seem like lots of work, I have made over 2,000 maps using the save as rectangular section png, and importing it into a new map, then use it as a guide. I've made around 3,500 maps using CC2/CC3/CC3+ over the years.
Took me awhile to. So don't let the learning curve stop you.
The cliff comment was that, for me, I couldn't do much until suddenly, it call came together and everything was obvious. (Everything basic, that is. One could work with CC for years and never master all of it.)
When copying effects from an individual sheet, you are aware that you can select and copy all the effects from a single sheet in one go also, right, and not just one by one. For many sheets at once, I still recommend the method above though.
Speaking of that... is there a way to purge unused sheets like there is for layers (have never used that, so I'm not familiar with it beyond just seeing it in the layers pop-up)? That would be mighty useful for keeping things tidy.
Hopefully that helps a little.
Cheers,
~Dogtag
