Issue with cc3+ new update and sheet effects
                    Hi Everyone,
I am having an issue with sheet effects in cc3+. This is a fresh install with the vintaryi cartographic collection installed (might be relevant but most likely not).
I started a new dungeon designer map. This is a large map. I have filled some stuff and was trying to create some hills. However, when I turn on sheet effects I am getting these holes in the fills that I am using. One fill is a solid color. The other fill is a bitmap that I am pretty sure comes with the base program.
When I zoom in or out, I get these holes in the fills (when they have sheet effects on). heres a link to two images showing this: http://imgur.com/a/NkwT4. I have also uploaded the cc3+ file. I have no clue what is causing this and have never seen it before. Nothing I am doing is complex. This is a completely fresh install of cc3+ with dd3 and cd3 and the newest update. Let me know if you need any more info.
I can't say with certainty that this is the issue but I think it probably is, and not the update. I can tell you that when I opened thatguy14's map it on my system (v3.78), I saw the spots. And zooming in and out made the spots appear and disappear on and off. Changing the color of the top shape to a brown bitmap fill removed the spots for me. This is similar to adding a sheet between two similar colors.
Perhaps Monsen or jslayton can chime in with more certainty one way or the other.
Cheers,
~Dogtag
This can happen with any effect that modify edges of entities, such as bevels and fades.
In my own experience this side effect is more common if you have a texture with a large tonal range (ie if the texture has a lot of very white or very black pixels in it.)
