Map disappeared
                    So, I was working on a map, I hit either the zoom out or redraw button, can't remember which and... everything is gone. This has happened, say, twice before. I didn't care the first two times, but this time I'd put a lot of work into this, and it just disappearing really frustrated me.
I've tried zooming in, zooming out, redrawing, nothing works. Ideas?
1. Select View -> Zooms -> to All Text. This brings up a dialog listing all text entity in the map. Pick either one of them, and the map should zoom to that text entry.
2. Create a new map in the same size as the old one, delete everything in this new map, then go to draw -> insert file and insert your old map into this one.
I had to delete outside the map screen layer and screen sheet, being careful not to delete the screen layer, and that usually fixed it.
It does take some trial and error, by hidden and freezing each layer, then try deleting a rectangular area outside the screen layer and screen sheet.
I especially suggest save as filename01, delete, freeze that layer, unfreeze anotgher layer, save as filename02, etc until you find it.
Then zoom extents and hopefully the map is visible again. Monsen's suggestions may be faster.
