Mahnheim, WIP
Recently got CC3+ up and running...then my laptop was in an incident involving gravity rendering it out of commission for some time....sooooooo
Here's my first CC3+ map underway. Using Fantasy Worlds from Annual 3, map size is 3000 x 2400 miles, so continent is a shade under this. Still to place forests and other features.
Glad you got your laptop fixed! Can't imagine the heart attack it must have nearly given you when it happened.
Like Pixel says that's a great start, but I have to agree about the rivers. I can see that you have two outlets to the sea from the largest lake, and that generally doesn't happen all that often. The rest are possible, even if they do join at some really quite interesting angles.
It might help to imagine river systems as trees, with the twigs and smaller branches in the uplands, and the main branches and trunks in the lowlands - the base of the trunk being the bit that reaches the ocean. Not all rivers are this classical dendritic shape (in fact a good many of them aren't), but its a starting point
Well done
Helped me when I first started
EDIT: this image explains it pretty much - http://i.imgur.com/TNtKWA4.jpg
Thanks all for your comments. I will be keeping them in mind and I hadn't seen that river tutorial previously. I've got 4 Fractal River types added which half in size each time and I've been joining as per the rule (the name escapes me) wherein Size 1 + Size 1=Size 2, Size 1 + Size 2=Size 2, etc. to give ever increasingly large rivers.
I'm looking at this WIP as still at satellite level and the fractal rivers are twisting and turning round small scale rises and falls in the local terrain which are yet to be revealed - I'm planning on doing a zoom in level map to reveal these turns, in addition to smaller rivers and terrain features. In fact I'm very tempted at this point to buy some annuals esp 2012 with Satellite Views and Cutting tutorials - I'm a big fan of doing a map in various scales all the way down to local.
Work continues and thanks for looking
Sheelon
