moving the map around when zoomed in
 UKgnome
                Newcomer
UKgnome
                Newcomer
                    Am I missing something obvious.
When I zoom in to a map area the only way I can move the map around inside the viewing window is by shifting the sliders on the window edge, is this the only way to move the map around inside the viewing window ?
For a more planned approach, you can also use named views
many thanks
I hardly ever pan because it seems to take a bit longer than mouse wheel zooming when the distance is quite great.
