Mountain drawing tools
Ralf
Administrator, ProFantasy 🖼️ 18 images Cartographer
The following came up in Simon's feature request thread:
Unzip the attached zip over your CC3 folder, start a map based on the new CC3 Overland BW style and try out the "Terrain Default, Mountains drawing" tool. Choose Draw > Fill with Symbols to see the settings for the filler and toy around with them.
I'm happy for suggestions how to get this to look "right".
Posted By: DavarisAs I was laying down mountain ranges last night, I was thinking it would be great to have something like the forest symbol, where you can draw a shape and a nice looking mountain range appears inside it.This is technically quite possible, but so far good result has eluded me. I toyed around with a mountains drawing tool for the new CC3 vector styles, but scrapped the idea when I couldn't get it to look quite right.
I tried it out but there was an error. Drawing forests worked, but mountains didn't.
As I drew out the shape for the mountains, straight lines appeared for the polygon I created, but no curved lines appeared inside it, like they did for the forest. When I right clicked to complete the polygon, there was an error sound and three error boxes appeared.
Error Box 1:
CC2
ChkData has no pending DRQ
SELREST
Error Box 2:
Warning
Campaign Cartographer 3 cannot perform
the command:
MINERALS/MOUNTAINS
Error Box 3:
(same as Error Box 2)
As for the second one, please try downloading and extracting the zip again. If the error persists, what settings do you have if you type FORESTOPT at the command line? Does it point to the correct symbol catalog?
I tried it again and got the same error.
I took a screen shot of it:
http://img5.imageshack.us/img5/1653/forestopt.png
It should be:
SELSAVE
SELBYP
FORESTLOAD #system\Fillers\CC3B_Mountains.FIL
FOREST
CHANGEL MINERALS/MOUNTAINS
SELREST
with a line feed at the end.
Is anybody else having this problem?
SELSAVE
SELBYP
FOREST
SELREST
Should I get a screen grab?
EDIT:
This thread has something similar to what I imagined.
FR Moutain Macro
http://forum.profantasy.com/comments.php?DiscussionID=921&page=1#Item_2
