Random Cities Sheets Walls
Are the walls supposed to generate on the buildings sheet? All of the other elements seem to generate onto the correct sheet, ie Roads are on roads, and buildings are on buildings, but Walls always seem to generate on the Buildings sheet, even if I have a different sheet selected when I run the command.
Now I'll go into my nuclear fallout shelter for safety.
When selecting, try this:
- Right-click, and then choose Layer from the pop-up menu.
- Right-click again.
- Click the WALLS layer, and then click OK. You don't need to click the checkbox for the layer. When you click a layer (without clicking in the checkbox) the layer is highlighted to indicate you selected it. That's all you need when selecting layers and sheets unless you specifically need to switch to, display, or hide the layer/sheet.
- Right-click and select Do It from the pop-up menu.
Incidentally, I believe the buildings are the only things on the BUILDINGS layer, so they are all easy to select for different actions too.The command line changes to read, Layer name [dialog]:
In the command line, if there is a default value or action for the command, CC3 lists it in brackets. You can automatically accept the default by right-clicking (or by pressing Enter). When the default value is "dialog", CC3 will display the appropriate dialog. In this case, it displays the Select layer dialog,
The dialog closes, everything on the layer you clicked is selected, and the status bar now reads, Select entities (X picked): where X is the number of entities currently selected.
Whatever action you were performing, er, performs.
Cheers,
~Dogtag
