No Rivers/lakes
I have installed the hard copy of CC3 and Symbol Set 1 and the downloadable as well. I tried both ways and I can still not get rivers. I am very frustrated because I can't find my rivers/lakes. On the left hand side where you have the icons for the different symbol sets, I have a second terrain option instead of where the rivers are. Any idea how to fix that as well?
the list, from the top of the sheet popup is:
land
sheets in between these 2
rivers
bottom of list
They are that way on my templates, you might check yours to see if they are listed like that.
Just select the rivers sheet and move it below the land sheet like i have it listed above.
I think I've found the problem that has been causting this bug lately. Re-run Patch 7 (no need to re-download) and it should get fixed. Or alternatively, simply unzip the attached file over your CC3 folder.
