How do you start your maps?
So I'm noodling with some ideas for another map and I was wondering how people get started on theirs. Do you do a rough sketch on paper, first, or do you just start drawing and editing the basic landforms in CC3+? Inquiring minds want to know.
If I start directly from CC3+ with a city I'll probably confuse myself.
For overland maps I usually start directly in CC3+ and start playing around, figuring it out as I go. Which is what I do with a city too, once I have an idea how the city is organized.
Then I go from there. Overland. I draw a continent, or coast. Decide, a bay would look good in a particular part of the coast or continent. And then close the multipoly.
Maybe do one or two fractal clicks.
Then add mountains or just a gray area and label it mountains. Add ruins near the coast or mountains, add a city and towns on thge bay.
Also, because I often use CC3 to create historical real-world maps, where I can alter the settlements and coastlines to reflect known landform changes over time, I usually start with a scanned map from an atlas that shows the area I need in sufficient detail, or with important items (like contour lines) already shown. In fact, I typically end up creating a composite map from scanned atlas images, because I'm generally wanting to be awkward and have a map showing an area nobody does at the scale I need - like a recent one I did for the ancient tale of the Argonautica, which needed all of mainland Greece, all of Anatolia, the whole of the Black Sea and all the lands surrounding it as far east as the Caspian Sea.
CC3 is such a powerful tool for this kind of work, because for a region like, say, ancient Mesopotamia round to the Indus Valley region in modern Pakistan-India, it's really easy to create new sheets to show the coastline for different epochs, as The Gulf slowly receded between the fourth and first millennia BCE, for example, then just hide the ones you don't need for a specific use. I've also been mulling over trying a recreation of near-glacial Europe, including Doggerland and the Ancylus Lake, but haven't got past the "nice idea" stage as yet!
https://www.cartographersguild.com/showthread.php?t=23255&p=338024&viewfull=1#post338024
Chashio is blessed with an enormous and totally unfair amount of artistic talent, and J.Edward is just as bad, but we forgive them because they are genuinely beautiful inside - just like their maps
This is J.Edward's pre-existing experimentation thread. I've put you right at the beginning because his work is totally stunning. He's a bit like Lorelei, in that it sometimes seems like there are 10 of him, to produce as many lovelies as he does.
https://www.cartographersguild.com/showthread.php?t=29817
You will find his equivalent of Chashio's sketch maps towards the end of this thread
