CC3+ Update 10 Error
I was going to install one of the new CC3+ Annuals (Vol. 4) and got told I needed to update CC3+. I downloaded Update 10 and got an error message during the install.
It says cannot create the file C:\Program Files\ProFantasy\CC3Plus\Images\StripingCA106.png A directory with this name already exists. Cancel the install and try again.
I clicked Abort and then it went and did some install of a a font and got the menu key'.
I checked and noticed I had installed Update 10 several weeks ago. So I'm not sure why the annual said I needed to update CC3+
So do I need to uninstall something or run a repair or something?
In any case, I recommend running Update 10 again and doing a repair install (if given the choice). If you continue getting the error message, I recommend you contact support
I didn't have any Profantasy product open, except the installer. I had to tell it Ignore to get it to continue installing an Annual when I had copied one issue of symbols over all ready.
My reply post got deleated, then showed up again, and then got deleated again.
I contacted support. The updater installer was still doing it even on a repair install.
Ralf said that the file isn't essential and it ought not to even be in that location. So if clicking ignore works just to do that.
