Help Please - Importing PNGs to Symbol Catalog under Wine (Annual 4)
 caveCrawler
                Traveler
caveCrawler
                Traveler
                    Has anyone successfully imported PNG files to create a Symbol Catalog under Wine? No matter what I do, it will not import a directory of PNGs or a single PNG file. I am following the tutorial from Annual 4. Thanks for any help.
What happens after that? Are you unable to browse to the folder? Do you get an error? Or do you not see anything in the catalog after you click OK?
If you don't see anything in the open catalog file, that's normal. Symbol catalog files don't display the symbols in the "map" area of the main window. They also don't display in the Catalog window on the left, since those symbols pull from a separate file, much as they do when you're working on a regular map file.
If you do the import but don't see any symbols in your open file after you do the import, try selecting Symbols>Symbol Manager from the menu to open the Symbol Manager. You should be able to see the imported symbols in there.
Does that help?
~Dogtag
edit: ok this is solved by manually entering the import directory path into the dialog box.
I slam into a wall on every annual.
I got the import working, used it, closed the map but now I am seeing red x instead of symbols.
I am more of a "Do this: 1. 2. 3. 4." kind of person
