Symbol insertion point
 mr tek
                🖼️ 1 images Traveler
mr tek
                    How do I set the insertion point for a symbol that cuts a wall?
If the symbol is not symmetrical to the wall, the predefined insertion points will not place the symbol correctly or cut the wall.
The standard symbols all work, but anything I create has no control over the insertion point except the 9 cardinal points and the center.
Most annoying. If I creat a point at the nearest grid point, I can place the symbol, but it never sees the wall and will not align or cut it.
I have looked at offsetting from the insertion point, but that does not seem to be the answer.
Or, use the old text-based DEFSYM command when you define it instead of the standard dialog, this gives full control over the insertion point.
